more 465 & 205 questions
Discussion in 'The Garage' started by yunit, Jun 7, 2002.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Was the 465 in the later model K5's the same as the later model k30's? By this I mean the output shafts.
    Is the bolt pattern the same on the 400 205's as the np208's?
    What I want to do is get a later model 465 with the 32 spline setup and slap it together with a 400 version 205, has anyone done this? My brain hurts from searching and trying getting a straight answer.
    I have started to put all of this stuff together for a tech article. My goal is to make a database of transmission, transfer case configurations/bolt patterns/shaft setups, adapter lengths and bolt patterns, then list what will possibly fit with what. If you have any specs please email them to me. Thanks, Pete.
    peter.snodgrass@verizon.net
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    As far as I know, the '82-on up 465 with the 32 spline shafts are the same as the '85-on up K30's using the 32 spline 465/205 combo. /forums/images/icons/wink.gif
