more 6.2 questions
Discussion in 'The Garage' started by BIGCHEVY4X, Jul 21, 2005.
  1. BIGCHEVY4X
    BIGCHEVY4X Registered Member
    Mar 16, 2005
    52
    El Cajon, CA
    What is the temp. gauge supposed to read in an 82 6.2 The 2 trucks i have been in only go up to 1/4 doing 65 on the freeway for a few minutes. Is this normal?
    Also what is the round thing above the alternator? It has a hose going from the oil fill tube to this round thing and then 2 hoses comming off it going to the intake crossover. Im not sure what this thing is supposed to do but mine sucked oil up out of the tube and blew it down into my intake.
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    my 82 k-10 6.2 temp gauge rides just below 1/2 all the time.except long hills i have the 700r4 3.42s w/35s od is rare.don't know about the other thing .never noticed till you said somthin about it.
  3. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    Looks like a mushroom??
    That "mushroom" dewhickey on the passenger side valve cover is the "Crankcase Depression Regulator"--It sends blow-by back to the intake to re-burn it in the engine,much like a PCV valve does on a gas motor...
    There isn't much you can do with it except replace it--it has a diaphram inside,so dont wash it in gas or carb cleaner--it'll kill it!..
    My 6.2 runs just a hair under 1/2 way on the temp gauge too..
    :crazy:
