More A/C problems with 1989 Blazer A/C- need schematic
Discussion in 'The Garage' started by SC-Texas, Nov 28, 2006.
  1. SC-Texas
    SC-Texas Registered Member
    Apr 11, 2006
    83
    Houston, TX
    Problem:
    When the dash is apart and everything is dismounted and laying on the floor so we can observe what opens and closes when the control switch is moved, the duct doors appear to be in the wrong positiion relaive to the position of the switch.
    i.e. switch at Max A/C & normal - duct door appears to shift air to defrost vents instead of the dashborad vents..
    Questions:
    • Does anyone have the vacuum schematics for vacuum motor (a/c-heating) from switch to each vacuum motor & the color codes.
    • Can we get a diagram of which duct doors should be open or closed relative to each position of the control switch.
  2. SC-Texas
    Apr 11, 2006
    83
    Houston, TX
    Bump for the evening crew
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
  4. SC-Texas
    Apr 11, 2006
    83
    Houston, TX
    Thanks! the vacuum switch was upside down!
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Sweet! I love cheap fixes! :cool1:
  6. SC-Texas
    Apr 11, 2006
    83
    Houston, TX
    Now the water pump has failed! No heat and we took the hoses off- the W/P wasnt pumpiong water!!!!!!!
