More about "cracked" 6.5 heads that are still good...
Discussion in '1982-Present GM Diesel' started by uglytruk, Mar 26, 2006.
  1. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    A friend of mine just called to say his '96(?) 6.5 TD (4x4) has a blown head gasket. 170k. Xcab, longbed, consrutuction site beater, worked hard... :hack:
    Assuming it is a head related problem, I recall reading a while back about 6.5 (& 6.2) heads that where discarded because of "cracks" that were just "superficial". Before the machine shop has him buy recons or spend money unessecarily, I will try a cooling system pressure test, (I have a pump).
    Does anyone recall the thread, if in fact it's on this site? Truck is running, I've not been told what it is or isn't doing, yet. I am a (former) ASE mechanic... :haha:
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    There are kits sold to put sleeves in the valve guides to prevent the crack propagation into a coolant passages. Some of the cracks are just superficial and don't continue. There is a lot of info on this issue over on www.thedieselpage.com
