more about the 14 bolt...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Apr 9, 2001.
    brought it home today. out of a one ton, so perches and shock mounts have to be moved. there's some rust in the diff, it's been sitting for a long time.
    1. the ring gear had 9.14 stamped on it. did GM offer a 4.56 gear in '80, on one ton crew cabs? (the math comes out to 4.555555555555555555555555555555555555555555)
    2. what seals, bearings and such would you guys replace before stuffing it under the truck?
    3. the tub under the perch had pitting on it from rust, ~5mm at the worst...
    4. since the shock brackets are going, i've seen some sweet hoop setups for the rear, can anyone direct me to a URL showing diagrams and such?
    5. do you fellas re-use your old perches, or fab new ones, or buy new ones? where from?
    6. any of you that have welded your spiders, any updates from you?
    thanks once again for the pick-and-probe!
    greg
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    For the perch parts check out <A target="_blank" HREF=http://www.ubmachine.com/>http://www.ubmachine.com/</A>
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5 [​IMG]
  2. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    To answer #1 yes 4.56 was offered.
    For the perches and hoops try this url <A target="_blank" HREF=http://www.bcbroncos.com/>http://www.bcbroncos.com/</A> and go to "rear suspension"
    Steve had a write up on the shock hoops somewhere on this site you might try to find it.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
