more axles ! *another set added *
Discussion in 'Pacific Region' started by uglychevyZZ4, Jun 27, 2004.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    I picked up a few more last night, good prices,
    -D44, 3/4 8 lug, 4:10, open 225.00
    -10 bolt, 3/4, 3:73, 8 lug, 225.00
    -one of same with 4:10 225.00
    * * * 10 bolt front 3/4 8 lug and 3/4 14SF rear 275.00 /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
    If you have more needs ask, me and a friend are stripping alot of axles right now to sell cheap..../forums/images/graemlins/thumb.gif
    Rob
  2. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    Re: more axles !
    whats the difference between a 10 bolt and dana 44 8 lug??
  3. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Re: more axles !
    DANA 44
    All domestic manufacturers have used Dana axles, and the 44, with its 8 1/2-inch ring gear , is likely to be a step up on anything smaller than a 1/2-ton.It was standard under the front of pre-1976 Chevy Blazers and 1/2-3/4 tons.
    GM CORPORATE 10-BOLT
    This 10-bolt, with a larger 8 1/2-inch ring gear diameter, replaced the Dana 44 that was used in the front of some pre-1977 GMs.
    I dunno, I hear the D44 is stronger.. /forums/images/graemlins/dunno.gif
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Re: more axles !
    The Dana 44 is slightly stronger. Main difference is in the way the housing was built, but the difference is not enough to pull a good 10 bolt to replace with a similar Dana 44 (it is a different story if you just broke a 10 bolt front though).
  5. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Re: more axles !
  6. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Re: more axles !
    You can also do crossover steering on some d44 /forums/images/graemlins/waytogo.gif
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: more axles !
    you can on a 10bolt also, if you change the knuckle
