More boring VSS issues.....Old in to new with a twist..
Discussion in 'The Garage' started by yeild2me, Feb 11, 2003.
  1. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Man, after spending the last 14 days killing myself to get my S-truck conversion done, I am running into the same VSS issues as others (just got finished with a 2 hour search).
    My 89 np241 has the mechanical speedo but the s-10 (which is a 90 BTW) has the electronic. I am using Painless wiring and it has the lead for the VSS. No prob, I ordered the VSS adapter today, but now I am concerned with the speedo not working.
    Are the s-series eltronic speedos the same as the fullsizes of the same year?? Will the adapter send the right signal for the speedo or does the speedo get its signal from the ecm???
    HELP!!
    Rob
  2. CK5
    May 19, 1999
    21,623
    701
    CO
    OK, sounds like you are in a similar situation that I was in, I have a 90 K5 (first year elec speedo) and when I swaped in the NP205 (mech speedo) I had to get a 241 tone ring (speedo gear thingy) and then have Donovan take it down a bit and machine a hole in the tale shaft of the 205 so I could screw in the VSS sensor in order for the VSS to pick up the elec pulses.
    It was kind of a pain until I talked to Donovan and he figured out how to do it, so you might have to go that route.
    Here is a pic of my 205, we put a plug in the old mech speedo cable output (top) so it does nothing. just under it you can see where the new VSS sensor plugs in (thanks Donovan).
  3. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    What T case came in a 1989 K1500 truck? just something id like to know I thought it was a 205 but mine looks kinda like that only flipped over due to IFS and the fn diveshaft being on the driveside... /forums/images/graemlins/deal.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif www.zombieoffroading.8m.net and http://bigboytoys.8k.com
  4. CK5
    May 19, 1999
    21,623
    701
    CO
    Should be a NP241 with drivers side drop.
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I have a VSS thats in line with the speedometer cable. It's a 4000 pulse per mile that I got from jagsthatrun.com part # 4PC. I know my 730 ECM (90-92 f-body) has a speedometer output, so mabye something like mine would work for you? /forums/images/graemlins/confused.gif
    Here's a link to all the VSS's they have http://www.jagsthatrun.com/Pages/SpeedSensors_Speedometer.html
  6. CK5
    May 19, 1999
    21,623
    701
    CO
    I don't think any of those will work, you went from a VSS to a mech and he needs to go from a mech to elec. When I did mine I called everyone including that jags place, they all had a solution for VSS to elec but none of them had anything for mech to elec.
  7. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    I found that the buffer is between the wire connector and the speedo....I hope that the painless adapter will give it the right signal....ortherwise I will be contacting donavon
  8. jmd
    jmd Registered Member
    Oct 25, 2001
    63
    Phoenix, Aridzona
    What ECM are you using?
