more carb help needed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Apr 14, 2002.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Ok I am having a hard start in the morning when cold amd when It does start it runs maybe 2 seconds and then dies,atart it again same thing,(this is with me having to put my foot on the throtle to start and keep it there just idleing to run) then start to work and have to use the gas and brake at the same time or it will die after about the first minute it will hold its own at a stop at the stop in gear the idle speed is about 650-600 after It is warmed up it will idle at about 800 out of gear after warm but will not idle (stay running) when cold..
    Spec are 73 350 750 rodchester from jet edlebrock intake msd-off road ign.,
    Any thoughts will be greatly thankfull for...mike
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Sounds like the choke is not closing.
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Is that the thing I might have read or heard about the flap not closing all the way and staying up like maybe about1/8-1/16" How do I adjust it to close all the way ( I think I have to bend the rod -maybe)
  4. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    Has it had a GOOD tune-up lately?
