More EGR trouble
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Dec 27, 2002.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Old Problem: SES throws code 32 on highway
    Replaced EGR Valve, solenoid, and vacuum lines. Check EGR passages with valve off, passages are open.
    Truck runs great for 2 weeks, now running like crap again.
    Throws code 32 when driving around town, light stays on for 5 minutes or so, then goes off, truck still runs like crap. All lines are properly connected. I am clueless, could the valve have gone bad already?
    Aaron
  2. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
  3. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    Check to make sure that the egr isn't actually hanging open. Make sure manifold vacuum is present at the inlet of the sol and not on the other side at idle. check to see if the egr is actually hanging open by working the plunger up and down, If that is ok I would take it off and inspect the mounting gasket and the egr passages.
  4. SickboySS
    SickboySS 1/2 ton status
    Nov 24, 2002
    154
    Auburn Ma
    mabey its the IAC valve
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    yea id check the Idle Air Control too, at least take it out spray it down with C&C cleaner and put it back in, or if you wanna spend more money, go and get another IAC. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  6. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    If it was the IAC, why would it still throw code 32?
    Aaron
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Ah the notorious code 32.
    If the EGR stuff is all new and the passages and vacune lines are ok then about the only thing I can think of is it is possible the MAP sensor is not working right.
    A code 32 is set by: EGR open command did not change MAP sensor signal. Normal EGR flow should cause slight decrease in manifold vacuum which would change MAP sensor signal.
    It could be the MAP sensor is just working enough not to set a code 33 or 34 but is malfunctioning enough to set a 32.
    A bad MAP sensor will also make your truck run like crap.
    Also check the vacume line to the MAP sensor.
    The MAP sensor has a direct affect on the EGR system because it is one of the sensors that the ECM uses to monitor EGR fonction.
    Heres some good info on EGR problems and operation: EGR Tech stuff
    Hope it helps
