More electrical problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Mar 3, 2003.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Heres the deal, alarm turns on and off (chirps and locks doors) while driving. Replaced everything related to the alarm, wiring included, no crimps, all soldered. Replaced door switches and fuses. Replaced battery terminals. Checked ignition wiring, replaced any questionable wires. Replaced ignition switch. It is still going off. I hook my multimeter to the ignition circuit between the ignition switch and the alarm and ground to the frame. This seems to remedy the problem for the most part. It still goes off occasionally, and the multimeter will show an almost instantaneous drop to 0 voltage. The only idea I have left is a ground problem. Where does the ignition circuit or switch ground to? Any other ideas?
    Aaron
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    A good ground is a good ground. All the circuits in the truck have the same ground....the minus side of the battery. Try running a good wire straight to your battery minus for ground if you can't verify a good one on the dash. As far as +12 volts where are you getting that? An alarm usually connects to a constant "ON" 12 volts and only uses the ignition to provide a "running" signal. If that doesn't work throw the alarm away and get a big dog! /forums/images/graemlins/wink.gif
  3. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    The alarm has a direct connect to the battery as well as an inline connect to the ignition wire. This is how it knows when the truck is on/off. Its not 12 volts, its more like 13.5, until the alarm goes off, then it drops to zero for a split second. I have a couple more ideas, but I have lost all optimism.
    AW
  4. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    AW
  5. Michael
    1,576
    Sherman, Texas
    I like my idea...toss the alarm....OK can't have that many criminals..... /forums/images/graemlins/crazy.gif
  6. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    This is truck no 4 in less than 2 years. I have had 1 totaled in my parking lot by kids driving a stolen car, one was stolen, and someone tried to steal my Camaro to the tune of 3000 in damages. Alarm stays
    AW
  7. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Time to get a garage or MOVE /forums/images/graemlins/eek.gif
  8. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    Yeah, I wish. I am at college, scholarships pay for me to stay on campus, not off, otherwise Id be long gone.
    Aaron
  9. Michael
    1,576
    Sherman, Texas
    This sounds more like an alarm problem than a truck problem....have you talked to the alarm manufacturer? Maybe another alarm....sorry I can't think of much more than you have done....
