More engine questions - intermittent dying
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Element, Apr 13, 2007.
  1. Element
    Element 1/2 ton status
    Mar 23, 2007
    314
    WV
    Still trying to get some problems with the Blazer ironed out. '87 TBI 350 with about 87,000 miles on it.
    New parts - cap, rotor, plugs, wires, fuel filter, O2 sensor, air filter, alternator, and alt belt. Ran a can of Seafoam through the oil, and about half a can through the brake booster line to clean the engine out a bit.
    Problem with the truck is that it intermittently dies when idling. It'll stumble a bit, and it seems like it's idling really low (no tach, so not sure exactly what it's at) and bogging. Right after it cuts out, it'll start back up; however, there's a pretty strong gas smell. I'm not sure if it could be a problem with something like the TPS (does a TBI engine have that?), or another sensor along those lines.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Any trouble codes?
    Bad idle can be caused by a number of things.
    Some of the most common are.
    TPS, Coolant temp sensor. Bad IAC motor. Bad EGR, Vaccum leaks, bad throttle body base gasket.
  3. Element
    Mar 23, 2007
    314
    WV
    Can't check the trouble codes with the paperclip method, because the dash light is out. AutoZone can't scan OBD1 vehicles, so until I buy a scanner myself, can't check the codes.
    I'm going to pull the TBI assembly off the intake this weekend and see if I can't clean it up some and check for any gunk buildup in the EGR, or on any of the sensors.
  4. dyeager535
    26,980
    Fix the light. Your sure the light is out, and the ECM isn't just faulty?
  5. Element
    Mar 23, 2007
    314
    WV
    A lot of the other stuff, like the high beam indicator, is also out, so I figure it's an issue with the dash circuit board or some dead light bulbs.
    Put a new coolant temp sensor in yesterday, and pulled the EGR valve out and tried to clean it out a bit, just to see if that'd help before I drop $50 on something that won't make a difference.
