more engine questions...
Discussion in 'The Garage' started by 84gmcjimmy, Nov 14, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    How many bolts should there be holding the tranny to the engine? I got 4 little ones (7/16 heads) from that thin metal thing covering the torquecconverter, and there was only ONE tight bolt holding the tranny to the engine, the rest were half way out. And there were only 2 more. How many is there suposed to be?
  2. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    on a sbc there should bebellhousing to block bolts!
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I think that's what I am talking about. There were only 3 though. All unbolted now.
  4. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    There are six bolts on most chevy bellhousings--a few I have seen 7 bolts--some motors have one in the top center of the bell,some dont. Many of the trucks I've swapped motor in have had more than a few bolts loose or missing--usually the hardest ones to get at--isn't that a coincidence?? /forums/images/graemlins/wink.gif
    I had a 75 2wd blazer years ago--when I tried to pull the 3 speed tranny out to install a new clutch,it wouldnt budge--I had taken all 4 bolts out of the tranny to bellhousing,but even prying with a crowbar it would not come out.My older brother,who worked at many GM dealerships as a tech told me too look again at the tranny--sure enough,there was 1 more bolt in the top still in--the Tremec 3 speeds have 5 bolts holding the tranny to the bellhousing--good thing I didnt pry TOO hard! /forums/images/graemlins/tongue.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/doah.gif
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Can I order new bolts, or how do I get the rest? I only have 3 out of 6/7.
    Luckily I have the body off, so all the bolts where easy to see and get out /forums/images/graemlins/laugh.gif
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    they are just a 3/8"x1.25" corse bolt that you can get at most hardware stores.
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay that sounds easy enough. Thanks
