more horsepower out of 305
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1st timer, Dec 10, 2000.
  1. 1st timer
    1st timer Registered Member
    Nov 26, 2000
    27
    florida
    heys guys thanks for all your responses in other posts really helped alot now wanted to know if by removing the catalic converter and putting flowmaster will it give me more horsepower and also removing the pollution pump. They don't do any emission testing down here(so. florida) any more so i don't think there'd be a problem. thanks for your responses.
  2. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    YES,,,get rid of that nasty ol' cat a throw it into the atlantic!!!!then install that sweet sounding flowmaster!!! if you want crackly noise then get a two chamber,,,if you want the deep throaty sound then get the three chamber....
    you will notice better power and such,maybe even better gas mileage!!!
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  3. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    It would help a little, but 305 and horsepower are not two words that should be used in the same sentencs. The duals you could still save, but I would not put any money in the motor itself, instead I would save up for a 350 then you would have a platform to work from.
    I thought I was wrong once,
    but I was mistaken
  4. k5king
    Jul 23, 2000
    571
    a 305 and a 350 both have the exact same H.P.!!!the only diff. is torque
    [​IMG][​IMG]
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    And 305s came from the factory with a higher compression ratio, too!!!!!
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    According to the spec chart, in 86 you could get a 305 with 155-160 horsepower or a 350 with 160-185 horsepower.
    [​IMG]FUN WITH 31's![​IMG]
  7. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple>Hey 1st timer,
    How many miles does your 305 have ? If it's around the 70,000 - 75,000 mark you'll be replacing the cam real soon, the 305's are notorious for that. If so, put in a little bigger cam at the time. I did this with my 305 I had in a 77 Impala and it made a world of difference. Some other things you could do is an MSD ignition system and a K&N air filter. The best thing you can do is keep it tuned up well, I used to beat guys with 350's all the time when I was younger. Good luck.</font color=purple>
    <font color=purple>L8r,
    .Riz.<font color=purple>
