More horsepower
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by loudandproud, Jun 28, 2000.
  1. loudandproud
    loudandproud 1/2 ton status
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    What are some not too difficult ways and not too expensive ways to get more horsepower from my blazer's 305.
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>What year is it? Certain things that are cheap for older trucks can be expensive for newer ones. i would start with the exhaust. A good set of headers, high-flow pipes and good muflers can bring out a lot of power</font color=blue>
  3. loudandproud
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    Its an '85 Blazer. I am going to put headers on it soon, and I already have dual exaust on it.
    <font color=red>Thanks</font color=red> [​IMG]
  4. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    a pair of headers, dual exhaust, nice mufflers, an aftermarket dual plane manifold, ignition upgrade.
    not too much money and very nice results.
    Knife.
  5. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    put a 350 in it or better yet a 454 or hay a 502 I know it is not cheap or easy but it is the right way to go form what I have read and seen for a K5 you need alot more that a 305
    [​IMG]Go prepared
  6. loudandproud
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    I want to put a 454 in it, but then I'd need to get a new trany too. I don't quite have enough money for that right now, but I am saving for one.
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Get an MSD ingition(sp?) they're great. A K&N air filter will help some but not much. Also get better gears.
    YEEEEE HAWWWWW[​IMG]
  8. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    I've got a 350 auto behind my 454 and havn't had any problems yet. I've owned the rig for almost 2 years now. I've got a stock 454, I believe there's a couple other guys with big blocks, or hi-perf small blocks that use a 350 as well.
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  9. J.R.
    J.R. Guest
    my 85 had the 305 in it,the first thing i did was get rid of the factory ignition.i put the msd 8360 dist.with the blaster 2 coil and the 6t box.thats there off road box,same as the 6a.just by doing that i got better mpg,it started better,and it even had more get-up and go to it.the msd isnt cheap.but i think its the best upgrade you can do for any motor.infact i run msd on all my motors.
    BIGBLOCK MAN
  10. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    I can't get my k5 to stop burning rich...if i put in a msd dist with a blaster 2 coil and the 6t box would it burn more of my air/fuel mixture?
    Bigger is Better
    Cameron Burnett
    82 Jimmy
  11. loudandproud
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    I was wondering how you can tell if your burning rich?
  12. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    just remember to gap your plug wider if you run the MSD.
  13. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    I agree with the previous posts. Get a good intake, such as Edelbrock Performer, follow up with a good carb (Edelbrock 600) and headers. Along with a good airfilter and the dual exhaust you alreday got, you´ve done as much as you can to get your 305 breathing without messing with the heads. Another thing that gets your engine going is a new cam, but as you probably know you´ll have to lift your engine out of the car...well, you could probably tear your front apart but that´s just a bigger pain in the @ss than lifting the thing out....what else?...hmm[​IMG]....well, you could always install roller rockerarms. They free up friction and improve valve "movement". If you get roller rocker arms with a slightly higher ratio than stock (1.6 vs. 1.5) you get more lift, which is a good thing when building torque. Wait !A double roller timing chain is a good thing. They last forever and never stretch (well..). Converting to electrical fuelpump and fan frees up a few hp. Of course this leaves you with a shopping list from h*ll[​IMG] Start with a new intake ! A 305 can be built to 250-270 good horsies without digging a endless hole in your wallet (and staying with the stock torque converter[​IMG]) The questions is, do you REALLY want to?[​IMG] Was this post to long ??...[​IMG]
    Andreas
    406cui of pure sh*t[​IMG]
  14. 82Jimmy
    Jun 9, 2000
    702
    My spark plugs get clogged about every 2 or 3 weeks with carbon. My exhaust smells funky. (No its not burning oil) and my mpg is like 7 on the highway. Something sounds sh%#& about my 82 Jimmy....
    Bigger is Better
    Cameron Burnett
    82 Jimmy
