More hydro assist questions
Discussion in 'The Garage' started by 84_Chevy_K10, Jan 22, 2004.
  1. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How did you mount your hydraulic ram to your tie rod? Pics?
    I know MOO makes a clamp on mount and there's the obvious weld tab idea. Any other ideas would be appreciated.
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I just adjusted the toe and welded on a tab. Any further adjustment requires a full turn or removing a TRE for half that.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You welded to your tie rod?
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I used the MOO clamp, which makes any adjustments to the tie-rid or ram very simple.
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    You can build a clamp, or weld to the rod (much easier). If you are using a ram you should have a rock rod of some sort as a stock one will bend beyond easily.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep, I know a beefy tie rod is in order before I mount the ram.
    I'm so hard up against a wall at this point it's ridiculous. I want to buy a front lock-right and a hydro ram and hoses and I really want a 175 amp MIG welder but they both cost about the same and I've only got money for one or the other right now. /forums/images/graemlins/rotfl.gif
    I'm thinking of just saving the money and maybe next month I can afford both. /forums/images/graemlins/thumb.gif
