More ???? on a TBI truck i just got
Discussion in 'The Injection Section' started by 84CUCV, Feb 27, 2007.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Well, just got a 87 with a 5.7. Cant get it to fire up. Has spark. i cranked it and my friend said he could see the inside of the tbi wet, so it has fuel. its a duel tank truck, one tank is out and the lines are just laying there. Would that do anything to keep it from fireing? I thought if i put it on the right tank it would not matter. hard to read the switch its very faded. So what am i missing? as always thanks for the help
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    At start up are you hearing the pump run before you fire it up? You should do for a few seconds. When cranking , the injectors throw a good amount of fuel out, you should be able to see that clearly.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK then maybe my friend was wrong. I did not hear a thing. I didnt know the wes a pump you could hear. Guess i not getting fuel. crap thanks for the reply
  4. 88-383
    88-383 1/2 ton status
    Sep 11, 2005
    142
    Tracy. CA
    Yup, as long as it's got fuel,spark and compression it has to fire!
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Not if someone has the timing so far off or lord help 180* out.
    Seriously though, when the key is toggled to the on position you should be able to hear the fuel pump run for 2 seconds then stop. If not i would first check the relay on the passenger side firewall.
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK where is the fuel pump anyway? thanks
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Like 4x4 says, on the firewall. It's just above and to the left (looking into the bay from the front) of the aircleaner. Black plastic relay cliped to the wall.
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK i got it thanks. Now i have a place to start.
  9. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    do any off you think the two tanks matter? i am thinking about running one for now and getting a fuel cell down the road. thanks
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Tanks don't matter, the switching valve changes which fuel pump and sender to use. Actually, i suppose the switching valve could be bad and that's why your pump doesn't work.
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK do you know how to test it by some chance?
  12. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Hi guys, got to check the truck out a bit. In this pic is this what you guys are talking about on the left of the air cleaner? put the key to the run spot and it clicked. so i guess its good? thanks for the help
  13. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    that's the fuel relay. You can power that red wire to run the relay for test. Manual tells you about it. I've never done it but I believe it bypasses everyhting and powers up your pump direct.
  14. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    ok thanks
  15. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    is there a way to test the relay?
  16. dyeager535
    26,980
    Yes. If it runs with 12V to the red wire, and doesn't without 12V to it, the relay is faulty.
  17. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks
  18. dyeager535
    26,980
    I better clarify though:
    The oil pressure switch will allow the truck to run even if the relay is dead. "It running" that I refer to, is the fuel pump, not the engine.
    If the relay is dead, starting the engine should take a bit longer as the oil pressure needs to build up a bit before the switch closes. If you power the relay (assuming it's dead) on the red wire before starting, that "lag" would be eliminated.
  19. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    think i got it thanks not to good with wireing yet.
