More on glow plugs (theory)
Discussion in '1982-Present GM Diesel' started by tRustyK5, Dec 10, 2002.
  1. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I've been reading up on the different glow plug controller set-ups (I'm going manual control) and noticed that the glow plugs will also cycle a little while the motor is running /forums/images/graemlins/confused.gif
    What exactly is the point of that? Obviously with a manual glow controller they would never cycle when the motor is running...so how important is it for them to do this and why do they? Is it an emissions deal when the motor is cold to help burn the fuel more completely?
    Rene
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The glow plugs will cycle when the temp is not the right temp, the reason is, fuel economy, engine life, and emissions of course.
    I used the manual, and I didn't notice the difference when driving it, once it starts, I let it idle for 1 or 2 min and then drive slowly for the first few miles, it works for me.
  3. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    It's called "after-glow." It's only to help keep the motor running when it's really cold and to cut down on the smoke caused by unburned fuel. It's not really necessary most of the time. I have a home made auto controller on my truck, and it doesn't have any after-glow. Only when it's really cold out do I need to manually glow for a few seconds after it's started to help keep it running. If I don't, it will sputter and die sometimes. It just makes the engine run smoother for the first few moments of running.
    If you don't after glow, it will puff white smoke for a few moments. The after glow helps cut this down.
    The factory after glow period usually only cycles the plugs for about a minute at most. It does depend on the ambient temp as well.
    Casey
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Thanks for the info. Our climate is pretty mild here so it probably won't be too big a deal here. The coldest it ever gets in down to the 20's once in a while.
    Does keeping the motor plugged in help at all?
    Rene
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Oh yes, if you can keep it plugged in, you should be fine. But if not, in the 20's you might need to cycle it manually after you start it maybe a couple of seconds every 30 seconds 2- 3 times, after that you should be OK.
  6. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Thanks again!!
    Rene
  7. arveetek
    Mar 1, 2002
    722
    I usually plug my truck in if it gets below 40. It doesn't really need it to start, but it sure starts much easier. With it plugged in, it starts at 32 degrees like it would if it was 100 degrees, just a quick blip of the starter makes it fire up. Plus, the heater is warm and ready to go.
    If I don't plug it in, it gets hard to start below 32. It will fire, stall, fire, stall, fire and then finally take off. I can tell it's much harder on the batteries, glow plugs, starter, etc.
  8. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Makes all the difference in the world. Before I was able to plug in my truck, it would start then stop and it took a couple times doing this before it would stay running. Now in 20 degree weather it starts right up and stays running. I dont have a manual glow plug switch though.
  9. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Yes it does help and it helps alot. Less wear and tear on everything. Just remember what Glade plugins say "Plug it in, Plug it in!" /forums/images/graemlins/grin.gif
  10. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    LOL...now I'll be humming that little tune every time I plug it in. /forums/images/graemlins/tongue.gif
    Rene
  11. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    I haven't plugged in my block heater yet this winter, and the truck has always fired up within the first second of cranking. The overnight temps here have been getting below zero F, too.
    I had some cold starting problems last winter, but a manual GP setup and a new set of batteries have fixed it.
