More Power Puller
Discussion in 'The Garage' started by WhiteBurb, Nov 14, 2005.
  1. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    Has anybody used one of these?
    http://www.morepowerpuller.com/index.asp
    Seems like it would be really handy to have in the truck. Just wondering if you guys think it would be worth the $138.
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I have been thinking about those for a while now. After seeing a truck being pulled out, only to have the rearend slide down into a pond, I thought it would be a good part to anchor a truck from the side.
  3. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    They look like a nice "Poor Man's Winch". I currently use a ratchet strap for all kinds of other pulling/tightening/etc type functions, which this would replace as well. I think it would be quite handy, and they are made right here in OHIO! :D
  4. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    They work awesome! I use the old come-along and have been using it for years. Its nice becuase u can mount it to anywhere on the truck if you need to be pulled from the front or rear or side.
  5. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    i have a cum-along i bought a few years ago... ive used it once lol :wink1: It took like 3 hours of cranking and re-setting it to get me out of a mudhole i was in... its slow going but its better then being stranded lol.
  6. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I have had mine for about 8 years now. BEST $130 I EVER SPENT!!!!
    That thing as pulled me outa more bad spots than I care to admit :rolleyes: It is INDESTRUCTABL! I have over loaded it, ran over it :doah: and it still works great. They come with a little wimpy handle that sucks, so I just made an insert for my Hi-lift handle that fits the More Power Puller and welded it in. They come with a nice little snatch block that U can use with 'em too.
  7. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
  8. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    puller
    I just got mine last week, I decided not to invest in the whole winch market. I also put swivels-rings on the frame, behind front wheel and in front of rear. The holes are already there. Swivels front and back also, MorePower and PullPal and HiLift; I'll get it out. Maybe even yank a Jeep.:D
  9. WhiteBurb
    Mar 10, 2005
    307
    Louisiana
    Thanks for the input everybody. I'm going to order one pretty soon. I thought it would be pretty useful.
  10. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Double check home depot or lowes. Not sure what they are rated at lbs. wise but mine was about $30.00
  11. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    the come-a-long has saved me once or twice. I have 2 2ton princess auto specials that cost me 29.99 each. They have literally towed my k10 up a mussy hill stuck in drive and not running.
  12. Gixx
    Gixx Registered Member
    Feb 20, 2005
    8
    albuquerque,nm
    If you are using one at altitude, I hope you are in some GOOD shape ! OH, and don't use a tow strap cause they stretch ALOT before the truck starts to move. Better than NOTHING, but a real winch seems to be the only way to go, or bring a friend with another truck to pull you out.
    My 2 cents.
  13. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I did some checking for other similar products in Northern Tools and this unit seems to be a good deal, with the only downside being the weight. The aluminum ones weigh half as much.
    Oh yea, ordered mine last night :D . I also ordered a 25' choker cable. between this and my hi-lift, I should be good to go.
  14. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    be even cooler with all the synthetic rope you fit on it. :thumb:
    j
  15. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    I've seen guys use a Hi-Lift jack to accomplish a similar thing....not ideal either, but with only a finite amount of cargo space, the Hi-Lift might prove to have more overall utility for you.... :thinking:
  16. WhiteBurb
    Mar 10, 2005
    307
    Louisiana
    I've already got a hi-lift, and its plenty handy. But for pulling from the side or something I think this puller would be the deal.
    Anyways, I've got a suburban, cargo space is not an issue. :laugh:
  17. '71k204x4454
    '71k204x4454 Registered Member
    Dec 28, 2004
    60
    Hood River Or
    This one is a lot stronger then the ones you buy at home depot and a lot longer cable. I've used it as a corner pull so the back won't slide down the hill when pulling someone out of the ditch in the snow. I've even used it to move bolders around in the yard and even set a telephone pole with it attached to a tree. You will be glad you got one of these instede of a cheap one.
  18. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    nother reason
    My reasons xact for using ratchets (HiLift,MorePower) & rings inside the wheels & fr & back, I can pull anywhere. When I camp, I just empty the Burb all over camp so I have room to sleep.:laugh:
    An added benefit of MorePower and/or HiLift in the pull is, if there's a break, the heavy stuff doesn't whip. Lets see, two MorePower would be as long as the Burb, hmm.:wink1:
  19. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    puller
    Dude, hate to see blood; the handle is soft because it's the fuse. The next weak link in line will be either the frame or the cable itself.:eek1:
