More power with a 6.2
Discussion in 'The Garage' started by BIGCHEVY4X, Aug 30, 2005.
  1. BIGCHEVY4X
    BIGCHEVY4X Registered Member
    Mar 16, 2005
    52
    El Cajon, CA
    Im rebuilding an 82 6.2 block and was woundering how to get more power out of it. I doubt there are many aftermarket parts for it but i was thinking maybe a cam intake headers and ehuast. I want to stay away from turbos and propane but there isnt much else out there? Does anyone make bigger injectors?
  2. Big89Burban
    Big89Burban 1/2 ton status
    Jul 19, 2005
    143
    Magnolia, Tx
    I had an 82 3/4 ton with a 6.2 in it. I know this it not what you wanna hear, but I asked my instructor (wyotech at the time) what I could do to make the 6.2 run good. He said the only one that he ever saw make power had a 6-71 supercharger on it :D
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    J-code intake, cleaned out manifolds, nice exhaust, and turn up the pump a little... but it'll still be embarassed by an Ecotec 2.2L.
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Hmmmmmm...... I need an excuse to get a 6-71 and a diesel as well :D
  5. 6.2LTrailblazer84
    6.2LTrailblazer84 1/2 ton status
    Jul 4, 2005
    201
    san diego
    Is that a roots supercharger?
    Don't those give you most your power at the low end of the powerband?
    And isn't that where all the diesels power is naturally aspirated? And don't turbochargers give you most your power at the high end of the power band, which is why they are used on diesels?
  6. resurrected_jimmy
    May 23, 2005
    2,241
    correct on both accounts.... 6-71 is detroit diesel speak for a roots type blower that came off of a I-6 motor with each cylinder measuring 71 ci
    one of the benefits of a roots blower is it delivers a constant boost as opposed to a turbo or centerfugal blower that has to spool up..... a roots blower will deliver a constant 8-9 psi (you can set the boost where ever you want) but this is a little on the high side of normal
  7. 6.2LTrailblazer84
    Jul 4, 2005
    201
    san diego
    About how much would it cost to use that set up? And how much power would you gain? Would you have to beef up your engine and driveline components to hanble it?
    And can you use propane injection with a roots type supercharger as well?
  8. resurrected_jimmy
    May 23, 2005
    2,241
    I am by no means a diesel expert but from what I know thefirst limiting factor you have to deal with on 6.2's is the injector pump won't supply enough fuel, after that I don't know what effects a blower would have on propane, I'm sure you could build the engine around that set up if you wanted to
    A 6.2 is a light duty motor so you are not going to pack in the power that you could out of a cummins I don't know how much power the bottom end can handle reliably....... I don't think a 1 ton drivetrain would complain though
  9. moturbopar
    moturbopar 1/2 ton status
    Feb 9, 2005
    387
    mesa az
    the powerband on a turbo depends on the turbo sizing in relation to the engine size. You can build an engine that could be making boost at idle, the problem with this is that the turbo will run out of flow in the upper rpms, and will have a tendancy to overboost.
  10. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    :saweet: so can i buy a new weind 6-71 for my 6.2? :D
  11. Big89Burban
    Jul 19, 2005
    143
    Magnolia, Tx
    I really dont know much about it. Thats the only performance thing I had ever heard about them.
    Mine ran pretty healthy but when I was up in WY. for school the elevation is what really killed it. It was on 13"s of lift w/14bff & 4.56's. If the wind was blowing at you that thing would just barely do 55mph :haha:
    Edit: It ran healthy until the tranny gave (while my GF was driving) and she didnt know what happened. So she didnt let off the gas. Long story short it killed tranny & broke the crankshaft all in one fell swoop :doah: I was on the side of the road in park city, Kansas bout mid way from houston to wyoming. Had to tow it back bout 700miles on a trailer. Spent about 2 months in less than 20* weather rebuilding the engine & tranny. It sucked bad :mad:
    I sold it back in '02. Should have kept it :(
  12. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    would there also be mpg improvement with the blower? tell there would be and thats all i need to convince me to get one now :D
  13. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'd say not a chance. You'd have to crank up the fuel to match the air and more fuel does not equal better mileage. Plus now you have one more thing the motor is turning, even if it is creating power. Like noted I'd really say the limiting factor of the Blown 6.2 would be the injection system. Not that I know crap about it. Modern Diesels run turbos not blowers, something to be said for that I guess.
  14. tRustyK5
    Jul 23, 2000
    36,169
    1,366
    E-town baby!
    DB 4911 pump and 6.5 TD injectors plus the blower would make great power. The fuel system wouldn't be the limiting factor at all. The limiting factor would be the fab and R & D required to make it work well. 8-9 psi is on the low side of what a decent turbo system would produce for a 6.2.
    Rene
  15. Big89Burban
    Jul 19, 2005
    143
    Magnolia, Tx
    Not a diesel expert myself but I do remember hearing tails about some older diesels (possibly 2 strokes) that used both superchargers & turbo's. That would be obsolete for today. Turbo designs have come a long way in the past few years and really cant be beat as far as reliability over a supercharger.
    Probably be best just to get the banks kit. Only other thing I can think of is trying to peice together a turbo kit for it.
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Old Detroit 2 strokes used both, they did so because they had to. THe Detroits needed the blower to push the air/fuel in, the turbo just helped power production.
