More Power
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Jun 8, 2000.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Hello....I am new to this page and have a big problem....The problem is I have a 84 Full size Blazer with a 2.5 inch lift with 33 inch Swampers.....My Dad wants to sell it because it does not have enough power,and get a newer Tahoe or Yukon....What options do I have to get more power??? right now it has stock 350 and corporate 10 bolt front and rear....any help would be great!! Thanks
  2. ziagong
    ziagong Registered Member
    Apr 5, 2000
    19
    CA
    Gears - I believe that blazer has 3.07's if its an auto, and 3.73's if it's a stick. 4.10's or 4.56's will make a huge difference. I run 4.56's with 40's and a 350 and it's still pretty good, but I'm going to go down to 35's. I can't wait to see how much power it has then.
    1972 K5 CST Blazer - 350V8 17x40x15
    Made for Mud!
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Hi, Welcome to CK5, its the best K5 site on the planet.
    A K&N filter will help some. An MSD ignition will also help a lot.
    http://www.blazer.coloradok5.com is now under construction[​IMG]
    YEEEE HAWWWW[​IMG]
  4. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
  5. ziagong
    Apr 5, 2000
    19
    CA
    Thanks Blazerguy, It's a work in progress....:)
    Made for Mud!
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Man, there is plenty of stuff you can do to get more power. First, get a summit catalog at http://www.summitracing.com
    You might wanna start with a new K&N filter, a set of Flowtech afterburner headers and an MSD box, then you can get a starndard rebuild kit or even better a stroker kit! While rebuilding, you can toss those old cylinder heads and get a a pair of Vortec heads from http://www.sdpc2000.com. Top it with an Edelbrock Performer intake manifold and Edelbrock Q-jet. If you got big bucks, get the Edelbrock Multipoint fuel injection system instead of the Q-jet. If you plan on sticking with the 33" tires, you should use 3.73 or 4.11 gears. http://www.4lo.com has a nice table that will help you choose the right gears. A nice rebuild on the tired old tranny, and you got yourself a Blazer many of us dream about.
    And tell your father ALL of this will be WAY cheaper than getting a newer Tahoe or Yukon and will be WAY more POWERFUL, STOUTER AND RELIABLE than a second hand vehicle.
    Good luck, and I hope you stick with your blazer.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
