More progress on k-5 pickup/flatbed conversion*Wheeling Pics*
Discussion in 'The Garage' started by muddermilitia, May 27, 2006.
  1. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Well yesterday I started tearing apart my truck. Not bad for half a days work.
    I should get the rest of it off today, My brother and friend are gonna help me out this weekend, so I will try and keep this updated as much as possible and let me know if you want to see more pictures.
  2. stockk5
    Apr 13, 2004
    2,037
    72
    Cromwell, CT
    awesome, just cuttin a truck cab apart welding it to the back and making a flatbed after that?
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Is that a "cab donor" truck that we see in the background?
  4. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    No thats my dad's 77 C-30 crewcab dually its rust free! I wouldn't tear that truck apart. I actually got a cab from a friend for a $100 its in pretty good shape
  5. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Alright, here's some pictures of what I got done yesterday.
    So today I am gonna clean up the frame a little and paint it with some black rustoleum paint, I figure nows the best time right?
  6. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Today's progress
    So today we cleaned up the frame a little and brushed on some black paint
    And then we cleaned off the firewall and underside of the pickup cab that I am using and also painted that black.
    Behind the cab are the dana 44 and 14 bff axles that I will be putting next year. This year's project is body swap/flatbed fabrication.
  7. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Alright, sorry I havn't posted any progress in a awhile here's a pic of an idea I came up with for the rear of the truck
    yes that is a front fender mounted in the rear, what do you guys think?
  8. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    The more I look at it, the more I envision having those rigged up as quick-detachable bedsides with a net tailgate between them when installed. Leave them in the garage most of the time, but pop them on when you need a little bedwall.
  9. Rhinopkc
    Rhinopkc 1/2 ton status
    Feb 2, 2006
    336
    Lake Havasu City, AZ
    No one will know if you're comin' or goin'!:haha: It's like some kind of redneck stealth technology, I love it.
  10. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    I have the PERFECT flatbed that would fit for you, you'd just have to come down here for it. It's this one:
  11. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Yea my dad said I should also put a hood in the rear too. But actually I am thinking of tapering the rear fenders. Or my brother made the suggestion of having the front of the fender hinged so you could have the fenders regular style for street driving and then when you want to go offroad, pull some pins, hinge the fenders inward and repin them. Its gonna be a little while before I work on the rear of the truck. I still have to swap wiring over and make a rear crossmember to mount the cab.
  12. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Some more progress
    So this is where I am at now. It took me a while to get the truck running again, somehow the ICM and PCM got fried :mad: so I replaced them and now it runs. The front cab mounts are bolted in and my brother and I are working on making some mounts for the rear cab crossmember.
    I'm using the crossmember from a pickup and have cut two plates that will be welded to the top of the frame with gussets and the crossmember will bolt to the plates. Here's how it looks now. The new fenders are bolted on and I put on my new swap meet doors, they just need a little bit more adjusting and then I can start cutting them into half doors.
  13. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Rear crossmember done
    We finally got the rear crossmember done
    We also cut out a piece of wire mesh that will be welded in the rear window opening after the roll cage is installed
    I sanded the hood and one of the fenders and sprayed them with Olive Drab spray paint
    I plan on cutting the door at the tape line to make half-doors.
  14. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    cool man good work. I like the mesh back window idea. The olive drab will be a good color too.
  15. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    that looks damn good i realy like that color. on the doors are you gonna just cut the part below the window are you gonna cut the top off the doors to?
  16. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I am going to cut off the top of the doors as well but I have been debating whether or not to weld the door tops to the cab so you dont see the door jamb when the door is closed
    But when you open the door only the bottom will swing out. I am also going to cut the door handle so only the part around the button remains
  17. Smokin'Joe
    Smokin'Joe Registered Member
    Jul 27, 2006
    50
    Butler,Pa
    Hows about a stepside bed?
  18. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I dont think so, im not a big fan of stepside beds, I got some ideas of how I want to make the flatbed.
  19. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    any more updates on this thing>???
  20. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    yea I got the other fender painted last weekend removed the trans hump from the old body(new cab is missing the hump) and got the main part of the flatbed welded up. I will try and get some more pics this weekend but I will be at the real truck club challenge on sunday.
