More progress on my 52f/56r swap *PICS!*
Discussion in 'The Garage' started by MTMike, Jun 21, 2005.
  1. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Well I ditched the tough country springs all around and went with stock 52's up front, stock 56's in the rear, and here's how we ended up......
    Front 52" spring
    Shackle angle w/ stock 52" - MUCH MUCH better than w/ the 2" lift spring...
    Ride height
    Rear shackle angle w/ DIY shackle flip n switch....
    Stock 56" spring.
    I will probably put the rears in backwards becuase my driveshaft is about 1-1.5" too long from the 12" lift, and that should provide enough room for movement w/ the driveshaft and save me from having to shorten it.
    Now I just have to finalize the steering and get the driveshaft ordered...... :D
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Good job, your shackle angles look perfect.
    Are you just going to go crossover on your 10b or is there a D60 in the mix??
  3. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Crossover's goin onto the 10b... i'm already in way too deep for this project this year.... I figure that I can pull the 10b crossover stuff off and sell it when (not if...) the 10b breaks...
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Good im collecting parts to do the same. Where did/are you getting your knuckle machined??
  5. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I got the entire kit less the steering box from Trevor over at WFO Concepts It came with the milled drilled & tapped knuckle (availability is limited, but he had one when I bought), steering arm & bolts, DLE's, drag link and a pitman arm.
    If he doesn't have the pre-done knuckle, he can do one if you send it in.... ORD does the same thing as well...
    -Mike
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Ow nevermind im trying to do this cheap, not sating im skimping on parts just cheaper then that kit. :)
  7. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    looks good now trim the fenders b/c there going to beat to hell out on the trail
  8. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    That looks good, are those 38 sx tires? Do you have any full on side shots with the stock 52's and 56's on? Looks good.
    Cory
  9. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Yes, they're 38.5x14.5 SX's I left the 3" body lift in there - it should help clear those tires more and since it's already there, I don't have to worry about un-correcting the TC shifter linkage, steering, fuel filler, etc...
    I don't have a full-on side shot because it was too dark by the time we were done w/ the rear last night...
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    shackle length in the rear? looks good!
    j
  11. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    6" hole-to-hole, courtesy of Kert too :waytogo:
  12. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Looking awesome. Glad you got it all straightened out. Truck is looking very nice!
