More questions about 14b ff swap.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Zeus33rd, Jun 14, 2002.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    #1) Is there any problems as far as the 1/2 ton brake master cylinder having/not having the "ooomph" to sufficently expand the wheel cylinders on the 14b ff? Are the wheel cylinders on the 14b that much bigger that the master cylinder couldn't supply sufficent volume?
    2) What back spacing on the rims are you guys using with the 14b? Does it matter?
    I stopped at the Les Schawb tire place today, I can get white spoke 8 lug 15x10's for $27 a piece. lol.....Uglier that $hit, but cheap. And I can get'em re powder coated at work for free...lol......Hmm, what color should I choose? lol! /forums/images/icons/crazy.gif
  2. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I have had no problems running my stock 1979 cylinder with the new 14 FF
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Cool, Good to know. /forums/images/icons/cool.gif Thanks.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Make your wheels BLACK!!
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    It worked OK when I went to a 14 bolt and kept my 1/2 master cylinder. It worked much better when I put the 1 ton master cylinder on. For $38 for a new one its a no-brainer.
  6. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Is the 1 ton master cylinder a direct bolt on?
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    My 3/4 ton Eaton has the same size rear brakes as the 1/2 did. 11" drums so I kept the same MC. Now if the replacement RE has 13" drums you might want to set up to the 1 ton MC. /forums/images/icons/smile.gif
  8. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">My wheels are 15x10 whitespokes with 4 1/8" backspace. I painted them with a can of black Krylon before I threw them on. All 15" steel wheels will fit over any 14 bolt drum. Get out the grinder for the front
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmm, I'm also curious if the 1 ton master cylinder is a bolt on? I thought the 1 tons had the hydro assist brakes....You'd also need the power steering pump to match the master cylinder right?
  10. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    No I think the PS pump is that same it just has extra hoses. But I may be wrong....
