more questions for the newbie
Discussion in 'The Garage' started by jj4465, Aug 2, 2003.
  1. jj4465
    jj4465 Registered Member
    Jul 31, 2003
    19
    Nebraska
    well i got my exhaust on today..i went with dual straight pipes...no cats of course...with 3 and a half inch tips..sounds mean and flippin loud....i was wondering what places in a city put on lift kits...and would a 3in lift be decent..and it wouldnt need that much adjusting such as the driveshafts and stuff? also i feel stupid but how do u get the window cranks off for the side windows on the inside of the door..one of mine is broken and i didnt know how they came off...thanks guys
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    those cranks have a little spring kind of clip on them, its a 4 or 5 dollar tool at the local auto parts house called a gm door crank tool...3" suspension lift? i havent seen one for these style trucks...4" is your way to go and you shouldnt need any driveshaft work...
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Or, use a philips screwdriver for that clip behind the crank. You should be able to push the door panel in far enough to see what you are doing. Reassembly is easy, just put it back on the new handle and snap it on. I won't tell you guys how long I used a needle nosed plier and put that clip back in /forums/images/graemlins/angryfire.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rolleyes.gif
    Make some friends, buy them lots of beer, and put that lift in together. Look for a friend with a cutting torch preferrably /forums/images/graemlins/thumb.gif The money you save that way can go towards the next upgrade....Installing the lift really isn't rocket science, but you might wonder if you need a mechanical engineering degree to remove some of those bolts on a 27 year old truck /forums/images/graemlins/grin.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] About any garage that does suspension work. Have you decided on what name brand you're going too get ??? The two most poppular are BDS, and Tuff Country. BDS has a life time warrenty. /forums/images/graemlins/thumb.gif
