more spark issues
Discussion in 'The Garage' started by PeteH, Dec 27, 2005.
  1. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    Theres no spark to plugs. So heres what I checked:
    Theres carbon residue on the contacts in my dizzy and I know there shouldn’t be any residue but its just proof that its been sparking and arcing a bit. The contacts were clean before cranking over, but after cranking a whole bunch now theres small traces.
    Theres a little over 50 ohms for the wires. Powers going to the dizzy when its supposed to and all wires are correct.
    And the plugs are brand new.
    I put everything together crank the engine and I still see zero spark to the plug when I test it.
  2. trikstark5
    trikstark5 1/2 ton status
    Feb 17, 2004
    169
    usa
    What kind of distributor are you running?
  3. PeteH
    Mar 26, 2003
    498
    San Jose
  4. Jagmeister
    Jagmeister Guest
    Make sure you have a good ground between the engine and the frame. There should be a metal braided ground strap somewhere.
    Is the HEI original or are you converting from conventional?
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Is this an old hei or are you going to a TPI computer controlled hei?
    Is your tach hooked up? Do you see 500rpms on the tach while cranking?
    You can use a test light on the negative side (tach) and i think you're supposed to see it blink.. Showing that the magnetic pickup is working..
    Sounds like maybe the module or pickup is bad.?.
  6. PeteH
    Mar 26, 2003
    498
    San Jose
    i do have a brand new braded ground line between the engine and frame. and the hei is original. but with a msd box (thats probably some prob there)..
    ...anyways..i am putting a stop to this and i think i'm just going to spend the extra little cash and put in the tpi stuff i've gathered over the year.. i was just gonna get it running quickly but i think i can afford to wait a couple more weeks and install the tpi instead.
    ryan get ready for the questions.
