More Spy Photos ~ Hydro Clutch Master>>>
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Burt4x4, Aug 18, 2004.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    The GREEN helps it stand out a lil better than all black. You can see my homemade resavour mounting bracket.
    You can barly see the slave cylinder down on the orange bell housing. See the braded line going down just in front of the bell, just to the right is the slave.
    I'll have to get better pics/closer ones.
    Damn all that black paint hides everything...
  2. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  3. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Get a pic showing where the reservoir bracket attaches if you can. I haven't decided yet how I will hang mine.
  4. Burt4x4
    6,854
    Ok, I simply used what was left of the bottom bolt that holds the booster to the bracket. The bolt had enough sticking out pass the first nut to hold the bracket and another nut(nylon locking nut). Look closly you can see were the green stops and a small amount of shinny nut is showing. I had a strip of steel that i cut and welded into a T then drilled holes to mount it /forums/images/graemlins/peace.gif
  5. OLD DAWG
    OLD DAWG 1/2 ton status
    Jul 20, 2002
    444
    MONTROSE, COLORADO
    Has anyone tried using a Mcleod hydraulic throwout bearing and master cyl. setup yet? I know they make a complete change-over for GM trucks and use the original bellhousing.
    But I've got to admit yours looks good. /forums/images/graemlins/waytogo.gif
  6. Burt4x4
    6,854
    I know Chaz (ex-blazer owner) buit his buggy with a vortec 6cyl with manual tranny and I belive he used the bearing type and he did have some issues with it..I think it leaked all over his cluch disk or something like that. This buggy is laid over quite abit so he uses the crap out of it.
  7. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    that paint makes it look really pretty /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
    ARQ.
