More stupid tach questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Feb 25, 2001.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I found a factory tach cluster junkyarding, stole it for $10. Only problem is the tach is screwed up (still got my $10 bucks worth of stuff though) It reads around 3K at idle, but seems to work otherwise. Whats the chances that I can just pull the needle and calibrate it with another tach? Were these known to slip? Can anyone rebuild it for less than a used one costs?
    Luke
    84 K5
  2. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Back in High School I had a '77K5 with a factory tach that didn't work. I could tell what resistor burned up and took it to a good friend (older) that had his own electric company. He said that it would be very difficult to fix unless he had all the schematics for the original tach circuits. Basically needed the original blueprints if you will to fix it. I really doubt you could just move the needle. If I was you, I would do some serious research into the original circutry and then take it to someone who knew what they were doing.
  3. mudpuppy89k5
    mudpuppy89k5 Registered Member
    Nov 3, 2000
    44
    Marietta, Ga
    A buddy put a factory tach in my '89 back when it was new. He was a mechanic for one of the Pontiac dealerships at the time and really knew his stuff (still does). To set the tach needle, he pulled it off the pin, then we turned the ignition switch on without starting the engine to get zero rpm. He pushed the needle back on the pin aligned with the zero rpm on the tach. Worked fine ever since. Hope this helps.
    John Perry
    http://www.mudpuppy.coloradok5.com/
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Cool deal! I look inside every GM truck I ever see in a junkyard. I have yet to find one that has a factory tach! [​IMG]
  5. Grim-Reaper
    7,385
    Atlanta
    Won't work on these tachs. Mine reads 1,100 at idle 1500 off and 7,000 at hwy speeds when it's turning about 3k. Most of them the spring (theres a name for it can't remember it) one or both have broken and it doesn't give the physical resistance needed. There are companies that will rebuild them but it's like $100. www.yearone.com has that information.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
