more suspension flex without buying new springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by four_by_ken, Dec 3, 2001.
  1. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Lets try this again...
    I want to increase the flex on my Blazer, but do not want to purchase new springs. Mainly concerned with the droop of the truck. I like the revolver idea, but they no longer sell them for full sizes. Plus, there are some negative stories I have heard. Any other alternatives?
    Anyone have any ideas. I am running an 8 inch lift.
    Ken H.
    '86 K5 up and coming
    14 bolt(Detroited),10 bolt,39.5 Boggers rear,
    TSLs front, 468 BBC, 350 trans, 205 transfer
    Rust free in Michigan!
  2. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Re: more suspension flex without springs
    There are 2 clamps that hold the springs in line. Take the bolt out. (basically what you are doing is allowing the spring to fully extend. But when sitting on flat ground the sides of the clamps will hold them in place.)
    I saw it a CalRocs. The fullsixe K5 had it done I believe. I also saw many Heeps with it to.
    Good Luck. KEN
    DANGIT it's not a bronco!
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
  3. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    longer shackles
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    If you don't already have them, put the teflon pads on the ends of each leaf to keep the edges from binding up. And radius the top of the end of each leaf so that it doesn't get caught on the bottom of the leaf above it. I've also heard that it helps to put grease between all of the leaves.
    <font color=green>Oh man, 4:10's are sure better than 3.08's!</font color=green>
  5. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    I have seen Anti Seez (sp?)
    between springs...
    Later Ken
  6. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    flipping the overload spring is suppose to help. it get the bend in going down instead up into the other springs. ill be doing this weekend hopefully
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
