more twin stick 205
Discussion in 'The Garage' started by jackedjimmy, May 20, 2002.
  1. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    I wanted to know if you guys knew any companies or even individuals out there that make a twin stick shifter for a np205. I made a post on the Garage forum and got replied that Avalanche engineering made one, but i called them and they don't.
    I think that people are getting the twin stick mixed up with a doubler t-case twin stick. I've seen them for DANA 300 t-cases and i was wondering if that could be adapted. Or if you know of anybody that made one for their 205 and would tell me how to make one.
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i recently made one, i got some ideas from other posts. do a search on twinstick and i am sure yolu will find some links to pics. as soon as i get my digi cam or my hyd hose to drive over to K10andy's i'll post some pics. kinda curd but functional. i don't want to put too much pretty stuff into this blazer.
    BTW, i used the original lever along with a 26"x1.5"x3/8 flat steel slab.
    ARQ.
  3. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    you could get a kit from wildhorses in stockton ca...they make a kit for a dana 20 transfer case but i could easily be modiflied to work with a 205..i dont know what kind of cost you would be lookin at...but even if you made one from scratch i dont think it would be that hard to do..that is if you have the resourses to build it
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    The magazine article a couple of years ago about doing this, they used a modified advanced adapter twin shifter.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, the article was in Peterson's and the twin stick they used was a modified Dana 300 twin stick...
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    that article was for a divorce style np205, the divorce style has a lot of room to work with. there is very limited space when working with the mated np205 and using the stock mounting pivot point for the levers.
    you'd be surprized how easy it is to fab some levers. i am sure you can go over to a machine shop and have the steel slabs bent for a reasonable price, if not for free. I had to use 1/4" angle iron on the shifter rods to make them work with the stock lever and the 3/8" slab that i used.
    ARQ.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Dang'd if you aint right! I went back and had another look, would have sworn it was mated. I do agree that it is a simple thing to do yourself. Seems like I've also seen some where a longer bolt was used to stack 2 slightly modified 205 shifters side by side.
  8. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    maybe it's a different article that were talking about.
    ARQ.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    No, it's the same one all right. What I was trying to say is that I thought I remembered it being mated, but when I went to look, it was divorced, just like you said. Sorry if my exhausted attempt at humor didn't make sense. /forums/images/icons/smile.gif
  10. jackedjimmy
    May 18, 2002
    195
    Redmond WA
    dothis wildhorses place have a web site or phone #?
    p.s. Thanks for all the good info guys
  11. Chaz88K5
    2,979
    Stockton/Lodi CA
    <a target="_blank" href=http://www.wildhorses4x4.com>www.wildhorses4x4.com</a> bada bing...thank you thank you...i am here all week /forums/images/icons/laugh.gif
