more updates on project camok5 **sept. 17**
Discussion in 'The Garage' started by 84gmcjimmy, Sep 14, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    well after (2) 5" cut off wheels, and my grinder getting really hot, I cut off all the bolts that wouldn't come off, and got the bumper off... then I got help to get the front clip off... here are some pics ...
    I HATE RUST
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Re: more updates on project camok5
    looks good, what all are you planning to do to the body?? narrowing??
    /forums/images/graemlins/thumb.gif
    -Chris
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Look at that!! It's all nekkid n stuff. /forums/images/graemlins/whistling.gif /forums/images/graemlins/doah.gif
    By the way, what's the line runnin from the firewall to the air cleaner?
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    the line that you see "attached" to the air cleaner is just sitting there, when I took the front clip off I put it up there so it wouldn't get hanged up.
    yeah, eventually it will be narrowed. right now I am working on taking it all apart and getting rid of the stupid rust!!
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    more updates...
    luckily I had 2 doors, a roof, and a tarp, it was raining out!
    how do I get the steering wheel off, do I need a special tool, or how does it come off, I got it down to this:
    more pics of what I did /forums/images/graemlins/yikes.gif
    I got the transfercase shifter unbolted, how do I get that little bar out now? /forums/images/graemlins/confused.gif
    Also, how come the stock guages have those weird connectors, I never took a picture, but they have 2 bolts holding them in, then there is no wire attached, there is just a few bolts coming from the back of the guage, into a metal thing on the dash /forums/images/graemlins/confused.gif weird /forums/images/graemlins/dunno.gif
    next day I work on it, I will get the doors off, and some other things, and look at the wiring /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    for the steering wheel, you will need either some type of gear puller or such or I went to the auto parts store and bought a steering wheel puller for like 8 bucks.
    -Chris
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Ill look for a steering wheel puller on Monday. /forums/images/graemlins/peace.gif
  8. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Another good tool investment is a lock plate compressor..If you ever have to dive intot he colume you will thank yourseld for buying it..It compress's the Black round plate under the sheel and allows you to get the snap rig out so you can take that plate out and replace the turn sig. handle and what not if need be..
    I bought one and used it for that reason..Then 2 weeks after I bought it I had to use it on the trail to attach my steering wheel back on.. /forums/images/graemlins/whistling.gif
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    how much do those usually cost?
  10. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Maybe under 10 IIRC...But worth it IMO.. /forums/images/graemlins/waytogo.gif
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay I'll look into buying one of those too.
  12. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
    as for the t-case. that bar u show in the pic dosent come out its apart of the braket.
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    how do I get the bracket off then? /forums/images/graemlins/confused.gif
  14. k5redneck
    Jun 24, 2004
    1,000
    mesa AZ
    go under the /forums/images/graemlins/k5.gif there is an arm coming from the braket to the front of the t-case. there should be a pin and carrter pin holding the arm to the t-case. put the pin and it should come out.
    p.s. its a 208 right?
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay thanks I will look at that tomorrow. yeah its a 208 /forums/images/graemlins/doah.gif
  16. k5redneck
    Jun 24, 2004
    1,000
    mesa AZ
    just wanted to make shure it was a 208. i would say its an easy job but rust sucks, so i say /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif the pin off and call it a day. j/k /forums/images/graemlins/ignore.gif
  17. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    LOL, so far the only thing I had to cut off was the bumper, hopefully I stay sane, and keep everything uncut for now
  18. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    So are you going to remember how it all goes together?
    Just curious, are you going to keep the factory gages or use aftermarket?
  19. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    im using aftermarket gauges. I took alot of pics of the engine bay, and around there so I will remember when I take everything off, then back on, where everything goes. the interior won't be stock at all, so I dont need any pics of that really.
  20. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    That's always my concern when I tear something down. At least it's usually not that hard to figure things out just by looking at what fits where.
    I'd like to switch to all aftermarket gages some day and do a nice custom dash.
