moroso oil pan question.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dragricinMT, Aug 7, 2001.
  1. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    I would like to know some info on moroso oil pans. In particular the 7qt deep sump and the 7qt kickout.
    I have a 78 K5 with a 400sb going in and want to upgrade the pan. Does the kickout cause any serious headaches changing starters? I do have hedman headers and a TH350.
    Also does the deep sump pan hang low enough to worry about? I wouldnt think so but would like any suggestions.
    THANKS
  2. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I have the deep sump on mine. Had no worries as of yet.
  3. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    I used to run a 7q on my chevelle I had. the starter was not a problem is all I know about that.
    Neil H.. Alabama.. '78 K5 400ci 4x4 AT,AC,PW Cheyenne. '74 C10 3spd/floor 250ci 4x2
  4. dragricinMT
    Jul 21, 2001
    135
    Billings Montana
    I appreciate the info. Ordering deep sump pan and pump/pickuptube, hope its here by the time i go to put my 400 together.
  5. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I'm getting a Moroso pan for my 496 and the I plan on getting the 8 or 9 quart pan. If the deep part of the pan just goes straight down and not out to the sides; your headers will clear just fine.
    74 Blazer
    Zepplin
    Check out my Blazer <a target="_blank" href=http://community.webshots.com/user/zepplin1976>http://community.webshots.com/user/zepplin1976</a>
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Exactly. I use the deep pan because I was worried about clearance to the headers. It's 9.5" deep and 7 quart capacity.
    Tim
