Most common cause for drum lockup?
Discussion in 'The Garage' started by pvfjr, May 1, 2005.
  1. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    My rear left drum keeps locking up with light brake application. Feels like the whole back end is getting kicked around violently. What gives? Mud? needs adjustment? Or is the brake lining gone, with rivets grabbing into the drum? What should I expect to find/look for... :confused:
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    axle seal went away gear oil all over brake linings and instant grab every time you touch the pedal! :D
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Either that or grooved drums
  4. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Ughh, don't like that one. Hope not! Haven't seen any oil coming out in the wheel area, hopefully that's not it. I wouldn't really mind replacing the drums though. Or maybe it's just time to do the home made disc conversion...
    So where is this seal though on a 12-bolt? In the diff, or at the wheel? Is it that one that has to be pounded in with a certain size pipe or something? How much to buy, how long to replace? Thanks.
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Mine will do that very rarely, usually after its rained for a few days and I havent driven the truck, I guess the drums rusted up bad or somethin. First stop at the end of the street, itll lock down. Tis rather entertaining when the kids standing at the bus stop go running for cover when they see a truck boiling smoke off the rear tires from a 20mph stop......
  6. dyeager535
    26,980
    My experience with a leaking axle seal and drum brakes is that COLD the "grabbing" problem was not evident. Two or three applies and after that, on dry pavement the one wheel would lock and slide even at 10MPH.
    Could be junk in there, glued pads coming off the backing piece, broken hardware, etc. Not hard to remove the drum from a 12 bolt, so shouldn't take long to open it up and see.
  7. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Mine tend to do it cold, I think. There have been trips where it never did get better though. Would grab when I stopped, and still be holding when I went to take off again.
  8. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Proportioning valve?
  9. dyeager535
    26,980
    Not for one side in the rear. Both rears run off the same line post-proportioning valve.
    My 10 bolt brake(s) were locking up when cold (attributed that to rust since the truck sits a lot) and sometimes/more commonly when traction was lowest, (mud, snow) it would also do it. Didn't really inspect them when I pulled the axle, but it wasn't the drums that were bad, and it wasn't the wheel cylinders.
