most STOOPID question - MODS DELETE - FIGURED IT OUT
Discussion in 'The Garage' started by 84gmcjimmy, Mar 5, 2006.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    EDIT:
    MODS DELETE THIS. IT'S FIXED AND WORKS!
    How the heck do I turn off the hazard lights? The switch on the colum of my 1984 GMC Jimmy won't turn the flashers off. I have tried every way I can think of to turn it off and it won't work. I had to dissconnect the battery for now. I looked in the little manual that came with the truck and it doesn't say anything about it.
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    all the switch does is push to turn on and pull to turn off. there is a screw in the center of the switch. remove it and reinstall screw and pull with plires to turn off. if it broken bad then new turn witch setup is needed.
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I can pull the outer piece but it doesn't do anything.
    I will take it apart monday.
  4. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Just duct tape over your flashers Stevey.
  5. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    There are two big fuses (round relays) right next to or on your fuse block, one makes the blinkers blink and the other controls your flashers, just pull the one for the flashers.
  6. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Did you pull it down hard enough to move the switch? It takes some force to move that piece inside the column.
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Alright I tried again, and like Randy said I wasn't pulling hard enough. It works fine now. Thanks
  8. sweetk30
    Nov 1, 2004
    25,547
    542
    :haha: :haha: he didnt pull hard :haha: glad it is fixed buddy.
  9. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Bahahahaha...
