Motor and tranny mounts
Discussion in 'The Garage' started by bigtread, Jan 19, 2006.
  1. bigtread
    bigtread Registered Member
    Nov 22, 2005
    32
    Virginia Beach Virginia
    Just need a little advice.:confused:
    :truck: I am clocking my 208tc which is mated to a th400 and I want to know if I could run sold motor mounts (existing rubber mounts are on their way out) with a solid tranny mount or should I retain the rubber tranny mount for any reason at all. This 86 k30 is not a DD so vibrations thru truck won't bother me.
    Trace
  2. dyeager535
    26,975
    You'll probably break the transmission case. Run poly engine/tranny mounts if you want something to last.
  3. goldwing2000
    goldwing2000 Guest
    You can run solid engine or solid trans but not both. There has to be some flex somewhere or hard parts will break.
    Just use some good polys and call it a day.
