motor dead?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Dec 1, 2001.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    My drivers side windo wont go up it is a powe window when I flip the button up I dont hear the motor running or anthing the passenger side works fin and so does the rear window. I have checked to see if it is getting power and it is so Im guessing the motor is dead is there anything else I should check?
    It just goes to figure as soon as I get the qjet problems fixed I still cant drive my truck unless I wanna freeze to death.
    1985 GMC JIMMY
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    When my window did this I pried it up from the bottom of the channel.
    A year later and I still haven't fixed it.
    It will be realy stiff going up so take care not to break the glass especialy if it is cold out.
    I got lucky(I guess) and mine crapped out when the window was 1/2 way up. You might see if any salvage yards in your area have them. If not then do what I do. Don't roll the window down. [​IMG]
    <font color=green> Too bad ignorance isn't painful </font color=green>
  3. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Well I need the window to operate. Plus there arent any salvage yards here does anyone have a different approach to fixing this?
    1985 GMC JIMMY
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check with your local parts house for a replacement motor. I've bought new AC Delco window motors for $45. Hardly makes it worth the trouble to mess with a used one and possibly have to do the job again soon.
  5. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    how hard is it to replace the motor?I have a 85 with stock doors.
    1985 GMC JIMMY
  6. SKI-'84K5
    SKI-'84K5 1/2 ton status
    Oct 11, 2001
    175
    Imlay City, MI
    if you really must have this window work and you don't want to spend the money for a new motor then swap driver ans pass side motors, granted you cant lower your pass window but your driver side will work, $.02
  7. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    I thought that you couldnt swap them becasue they wont fit on both sides of the truck.Is there anyway I can just unbolt something in there and raise the window?
    1985 GMC JIMMY
  8. SKI-'84K5
    Oct 11, 2001
    175
    Imlay City, MI
    the motor for my 84 was new and came w/ mounting directions for drvr and pass side mounting
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It's not too hard. Just follow the directions that come with the new motor. Should take less than an hour to swap the motor and put all the trim back on the door. [​IMG]
