motor deiseling
Discussion in 'The Garage' started by hi pinion, Oct 27, 2004.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    DAMN!! its doing it again. IT wants to keep running when i shut it off.Anyone? /forums/images/graemlins/thumb.gif
  2. dyeager535
    26,975
    I'm guessing you don't have a Q-jet with an idle kicker solenoid hooked up thats malfunctioning do you?
    That was one of the easiest "fixes" I've ever had on a vehicle. Unplug, dieseling stopped. /forums/images/graemlins/smile.gif
  3. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    When this happened with my old carbed 1/2 ton I would fill a 2 litre pop bottle with water , warm up the motor and pour it down the carb slowly while reving it up
    Being careful not to let it stall out or pour it in too fast and hydro lock it
    This works great and is a cheap (free) fix to clean up the carbon that is causing the run on
    You may have to clean your spark plugs when you do it
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    That is a tricky deal with that CCC carb, I bet that your hi idle is sticking. It was last time I worked on the truck with you.
    I had the same problem when my K5 had the same fuel system as yours, I fixed it by pulling the complete system along with the motor and put something else in. /forums/images/graemlins/histerical.gif
    Just shut it off in gear and it won't do it.
  5. hi pinion
    Sep 25, 2003
    5,354
    But shutting it off in gear isnt the right way to fix the thing. /forums/images/graemlins/thumb.gif
  6. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Have you adjusted your timing lately. Sounds like it needs to be timed.
    Or are you running a low octane fuel in a motor that needs higher octane?
  7. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I second the timing. Mine used to diesel at 8* BTDC, I put it at 12* and haven't had a problem since. Before you get too far into it, try messing with the timing.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    More timing is what makes it diesel acutally.
    Set your timing at 4* or where it belongs and set your idle correctly and it will stop dieseling.
  9. hi pinion
    Sep 25, 2003
    5,354
    [/ QUOTE ] Its brand new crate motor. Shoudnt i be ok with just regular 87 though??? What about a vacum leak?? Nobody said anything about that. /forums/images/graemlins/thumb.gif
  10. dyeager535
    26,975
    9:1 or less *typically* is ok with 87 octane on motors even with junk heads, as long as the timing isn't too advanced.
    Backing off timing is easy enough to do, worth a shot.
  11. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Derrrrr.... /forums/images/graemlins/doah.gif I mean I started at 12* and went ti 8*--sorry for the misinformation. /forums/images/graemlins/screwy.gif
  12. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    First thing I would check is timing (make sure to plug of the vacuum advance). check for vacuum leaks. Then check make sure the carb is adjusted right. Oh and quit buying the cheap gas from Arco You cheap basterd /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/rotfl.gif
  13. hi pinion
    Sep 25, 2003
    5,354
    [/ QUOTE ] /forums/images/graemlins/rotfl.gif Go tell it on the mountain Brother. /forums/images/graemlins/rotfl.gif
  14. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Timing and check the choke.
