Motor guru's rod help ?'s
Discussion in 'The Garage' started by backyardbuilt, Jul 5, 2004.
  1. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Motor guru\'s rod help ?\'s
    I am in the process of putting a new crank in a buddies motor he lost a rod bearing. This is the worst I have ever dealt with very little bearing was left and the rod bore is slightly galled from running on it for a reasonable distance after it started to knock. Do rods get out of round if they were banging around in there for too long, and is that galling gonna be a problem, you can see it but just barley feel it. Can I just get a new rod and put it in to replace that one with out hurting the motor (not sure if the rotating assemble was balanced by the previous owner). And are 305 rods the same as in could I use one since I have a couple here. Or should I just put a new bearing in and hope for the best. Becuase if I have to take the rod out I will have to pull the head so I should just to a complete regasket if I have to go that far. But thats more than I really wanted to do at this point.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Re: Motor guru\'s rod help ?\'s
    Dude, don't take any short cuts..If you smokes a rod bearing, get the rods re-resized. Chances are the crank is messed up too...Do it right the first time...I vove for pulling the motor, turing the crank, re-sizing the rods and new pistons and rings and bore the block.
    If you doi it right and do all the prep-work yourself you should be able to get all that done for about $400...The shop that build my motors charges:
    -$110 to grind a crank (this price INCLUDES balancing of the rotating assembly too)
    -$80 to bore and hone
    -$70 to re-size the rods
    Pistons and rings for SBC's are CHEAP if you just get OE replacements and not some fancy forged stuff...
    Chris
  3. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    I would not take short-cuts, there is no such thing. /forums/images/graemlins/shame.gif
    Have you considered purchasing a shortblock? /forums/images/graemlins/thumb.gif /forums/images/graemlins/peace.gif
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Chris
    [/ QUOTE ]built lots of motors, some high performance, no shortcuts on the bottom end, unless you like doing it again (for free) /forums/images/graemlins/whistling.gif /forums/images/graemlins/waytogo.gif
  5. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    There is supposedly only 12,000 miles on the motor. I am putting a new crank in. I think the bearing was bad when installed and thats why it let go so early thats why I was hoping to only have to switch out that rod and do the crank and new bearings (rod and main). All the other bearings looked new practically. How bout the ? about 305/350 rods are they different.
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've always felt if you need too replace the crank shaft, then go ahead and do a complete rebuild. If in question about the rods, replace them.
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the rods are the same, the cranks are the same also, BUT they are ballanced differently from the factory.
    i would change the rod, rods will be out of round from banging around.
    if the motor only has 12k on it then i would just put rings in it, unless the pistons show alot of wear. here the are some prices around me for parts
    cheap flat top pistons $60
    hastings rings $32
    felpro gasket set is $35
    clevite rod bearings $15
    clevite main bearings $23
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I don't see how much different they could be on stock motors. Crank is the same as a 350, bore is smaller on a 305. Compression was raised on 305's but I think that was in the heads. Betcha they are the same 5.7 inch rods as most small blocks ( 400's are shorter ) /forums/images/graemlins/k5.gif
