Motor Help
Discussion in 'The Garage' started by Mudgod, Jun 29, 2006.
  1. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    I have a 350 TBI Motor that hasn't been turned over in a year. It was running before I messed up and bent the frame. It will not be long before I'm ready to stick it in the new Jimmy.
    Do I need to do anything to it before I try to start it?
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I'd take the plugs out, put a small amount of light weight oil down the bores and turn it over by hand for a minute just to lube up the bores. Pull the dizzy and prime the pump and galleries.
    If any seals have gone bad there's nothing you can do to help them really. If they leak you'll have to change them. You should be ok after a year unless the motor's just been sitting out in the open.
  3. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Southern Speed, you took the words out of my mouth.
  4. Mudgod
    Dec 19, 2004
    92
    Gilmer, TX
    I didn't know if I needed to that or not. Thanks guys.
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Hope you cleaned your teeth first!:D
