Motor mount bolts size?
Discussion in 'The Garage' started by Art'74, Dec 17, 2006.
  1. Art'74
    Art'74 1/2 ton status
    Dec 21, 2004
    145
    OKC
    I am putting a 454 in for a 350 and do not have the motor mounts bolts and want to get the correct size.
    Please share with me the correct size/thread/length or whatever info. I need to go get the correct bolts for the motor mounts.
    TIA.
    Art
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    To bolt the mount to the engine or the through bolt between the mounts?
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    mount to block is 3/8" x 1" or so. mount to mount is 1/2" I believe, maybe 5" long??
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If you're replacing a 350 with the 454 then all the bolts you currently have will work.
  5. Art'74
    Dec 21, 2004
    145
    OKC
    Sorry about NEI.
    I was asking about the bolts/nuts/washers that go thru the the mount not the mount to the engine/frame.
    Just FYI, I don't have the bolts that came off the 350 so that is why I was lost.
    Thanks for the replies.
    Art
