Motor Mount Issue
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by justiz00, Mar 29, 2007.
  1. justiz00
    justiz00 Registered Member
    Dec 11, 2006
    83
    Central Texas
    Heres the deal. I purchase this frame ('84 by the vin number). Removed the old frame side motor mounts (thought polys replace the whole thing). Threw the old ones away. Now every replacement mount I look at is too large. The mounts I pulled off were bolted in with 3 bolts. I hold the replacements up to the brackets and only two holes will line up at one time (2 top holes or 1 top and 1 bottom). Mounts for the 350 and 6.2 are the same, later models have 4 bolt holes. I have not tried the 6 cyl mounts yet. Any Ideas.
    Thanks in advance!!
    j
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Are the back side of the mounts(part that touches the frame) flat? Are they countoured? I recall a while back that I kept getting motor mounts for a 88 truck instead of the ones I needed for the Blazer. Try going older or newer on the mounts and see what they look like.
    IIRC I had to go 3 years older for Autozone to get me what I needed.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The 73-86 truck 73-91 blazer suburban mounts are 4 hole but only 3 are used, made that way for working on both sides.
    If you can not get the 3 to lign up you have the wrong mounts.
    I will get you picks later tonight for what you should have
    There is one difference in 2wd and 4wd models, the 2wd mounts sit a little lower, about 1/2 inch lower.
  4. justiz00
    Dec 11, 2006
    83
    Central Texas
    Here are what I have. Sorry for them being dark, not dressed to open the garage door.
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Here is what I have:
    Yours seem a little big :confused:
  6. justiz00
    Dec 11, 2006
    83
    Central Texas
    Thanks. I got the right ones. I guess the ones I had were from a truck. Had only 3 mounting holes. The ones from autozone have 4 holes and line up right. They are about 1/2" shorter than the 3 hole mounts. Thanks for the help guys.
    ps. Had to get mounts for a 77 K5 4x4 w/350 motor.
  7. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Cool.
    I am guessing you have a 6.2 L diesel right?
  8. justiz00
    Dec 11, 2006
    83
    Central Texas
    5.9 Cummins with Crewcab59 blockside mounts.
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Does he make mounts to use the GM engine mounts?
  10. justiz00
    Dec 11, 2006
    83
    Central Texas
    Yes and has a business that does diesel installs in aftermarket applications.
  11. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I know that I follwo his threads, just didn't know his mount uses chevy mount.
    I thought he used Dodge cummins mounts.:o
  12. justiz00
    Dec 11, 2006
    83
    Central Texas
