motor mount pics
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by RGV72BLAZER, Sep 27, 2006.
  1. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    anyone have any stock motor mount pics? need several angles. trying to help out Kert @ DIY4X build the Gen1 x-member. need some pics of clearance between the x-member and oil pan. also of how the assembly comes together at the shell & horn. thanks.
  2. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Here are some pics I have of the stock engine crossmember in my 69 K20.
  3. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Here are two more pics that I left large for better detail
  4. RGV72BLAZER
    Jan 23, 2006
    2,425
    ...thanks...wouldn't happen to have a pic of clearance between the oil pan & x-member?...
  5. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    This weekend I will try to get a pic of that from my K5 that still has the sbc and also a pic of the clearance of the bbc in my 69.
  6. RGV72BLAZER
    Jan 23, 2006
    2,425
    thanks...it is much appreciated
  7. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
  8. RGV72BLAZER
    Jan 23, 2006
    2,425
    perfect.
  9. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Hey, is the X-member going to be able to bolt forward or back from its original position? It'd be nice to have that option-tuck the engine BEHIND the front axle.
    After I move my front axle forward, and depending on where the engine pullies are in conjunction with the X-member, I'd like to have the option of moving the engine/driveline back so the engine pullies are behind the front axle. BTW, I'm also going to move the rear axle back too.
    Also, keep us posted (i.e. pics, updates, etc.) I'm very interested in one!
  10. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Here are some pics I took this morning.
    The first few are of the stock engine crossmember in my 69 K20 that I put a BBC in. Again, I used some washers to raise the engine up slightly and also moved the crossmember forward about 3/8" to gain oil pan clearance. The BBC has a truck oil pan.
    Here is the stock engine crossmember in my 70 K5 with the stock SBC.
  11. RGV72BLAZER
    Jan 23, 2006
    2,425
    thanks for the pics...will keep things posted
