motor mount pole
Discussion in 'The Garage' started by S. Burnham, Jan 14, 2006.
which mounts would you run if vibration was not an issue
  1. solid steel mounts
    6 vote(s)
    14.6%
  2. standard ruber mounts
    17 vote(s)
    41.5%
  3. energy suspension mounts
    18 vote(s)
    43.9%
  1. S. Burnham
    S. Burnham Registered Member
    Dec 12, 2004
    64
    hattiesburg, ms
    what motor mounts do you guys recomend. I have used solid mounts in race cars in the past and liked them. I just don't know about the performance in a 4 wheel drive application.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I just run regular replacement ones , I wouldn't like the poly stuff with the way my tranny hits second .
    The ones on my engine are still the originals . The tranny ones are 2 years old .
  3. diesel4me
    Jul 24, 2003
    17,546
    936
    Massachussetts
    Not good..
    I think they cause problems..I rode in a few cars with solid mounts..like riding a chainsaw..seen a few tranny tailshafts snap thanks to a solid tranny mount,and stock motor mounts..
    I'd be scared in a 4x4 that frame flex would crack the block in half,or the tranny case..definately NFG for that application!..race cars,well,maybe..
    I've never seen a 73 up style GM mount break,ever!..the way the steel is bolted over them,its practically indestruco!..the older style ones could separate,but most replacements had a safety "catch" built into them..I'd run stock mounts,and a chain on the drivers side with an inch of slack,and never have fears of any problems..:crazy:
  4. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    Yea, stock chevy mounts are tough. The rubber went bad in one on my k5, ran it hard for two days at the local mud bog and no prob.
  5. dyeager535
    26,978
    I'd go with poly if starting from scratch. Engine mounts typically don't go bad, but the tranny ones do. You don't want to mix ANY mounts up. (poly/rubber, etc)
    I would stay away from solid...the frames flex way too much in these trucks, and that would put immense strain on the mounting points.
  6. S. Burnham
    Dec 12, 2004
    64
    hattiesburg, ms
    ok so no solid mounts for me.
    thanks for your input guys.
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    frame flexes too much for solid mount IMO.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    incorrect, if running solid motor mounts ALWAYS run a rubber or poly trans mount. there has to be some give somewhere.
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    always I wouldn't 100% agree with but you are correct. mixing up mount is not a bad thing, if done right. You want it to get looser as it goes downstream. Say, solid engine mount, poly tranny mount or poly engine mounts, and rubber tranny mount.
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    seen too many dragcars running solid/solid break the back of the trans completely off. name one good time to run a completely solid mount setup...
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    overbuilt chassis. Don't think we have a bushing in the dirt modified car. next chance I get I will look at the transmission mount. The engine uses a mid plate and solid motor mounts in the stock location.
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    When it is a Drag car and you've got a engine plate and a midplate.
  13. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    this is a good question with as many answers as people reading.
    my personal opinion is run wahtever. anything will do. follow a few guidlines and you will be better off though.
    if you want to run polly mounts on your engine, run polly mounts on all of your engine, transmission and transfercase mounts. and i mean all to include the side bracket on the t-case if you have it. same with rubber or solid steel. this way they all have the same amount of flex. now i personaly would not run steel mounts. not enough flex to keep up with the frame of a 4x4.
    also i prefer polly over anything else. out of ALL the bushings on my truck only two are rubber. they are the rear spring eye bushing on the rear springs. soem day i will change them out, but with the double shackle design im sure they help with flex a bit. some day i might get it driving as well so i can find out.
    Grant
