Motor mount Q
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by k5kev, Jun 19, 2006.
  1. k5kev
    k5kev Registered Member
    Dec 25, 2002
    57
    Anaheim, CA
    I'm getting ready to drop a new motor on a bare '72 4x4 frame, with original engine crossmember. It appears to me that the motor mount holes in the crossmember are about twice as big as the motor mount bolts???? Is there supposed to be some kind of bushing/shim/whatever to fill in the gap??? Or did GM design it that way and I just use a big ole washer so I can tighten the mounts down???
    Thanks in advance for the replies, I don't want to screw this up!:D
  2. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I was wondering the same thing. When I pulled my motor 4 years ago it had huge honking washers on the bolts in the crossmember. They might have made the holes oversize for adjustability. Tolerances probably sucked 30+ years ago.
  3. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    get some tips from burt4x4 or greg72
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I can't recall what was there but I know what holes you speak of.
    I removed my old x-member and installed 73+ version...so I can't remember what was holding the old engine mounts to the original x-member...that was like two years ago..:confused: :doah:
    Good luck
    Burt
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yes, there is a big washer that is about 1/4" thick that is used on those bolts. It reminds me of a crank balancer bolt, just smaller outside diameter. ;) If you need a measurement or anything, let me know.....I'll measure mine.
