Motor Mount?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89VJimmy, Nov 9, 2001.
  1. 89VJimmy
    89VJimmy Registered Member
    Mar 6, 2001
    12
    Lancaster, PA
    My 89 has the four speed stick. Lately (last 6 months or so) when I come off the clutch a little hard something comes up and hits the floor pretty hard. Looks like it could be the transfer case itself. Since the tranny and transfer case mounts typically use gravity and don't prevent the drive train from rising, could it be a motor mount? It doesn't seem likely, but I'm running out of ideas. Anyone seen this before?
  2. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    You'd be surprised how much the tranny can move when the mount tears. The engine mounts are captive in a metal clamshell but can also be loose enough to allow a lot of movement. I would set the hand brake and then SLIGHTLY engage the clutch while someone watches the driveline for movement. My guess is that one or more of your mounts are toast.
    Good luck,
    Mike
  3. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I'd guess tranny mount.....
    Stuck?...Hell no..I still got some gas left..
