motor mount
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 69K5, Apr 9, 2002.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    I just bought a .350 from Bigbad75K5 and my motor mounts are different. the ones on the .350 are the usual 2 piece with the big bolt in the middle to act like a pivot point. My .307 has three bolts that go directly into the block and one big one that bolts to the crossmember (frame). These look like they have the same spacing as the .350 mounts. I think the .350 will bolt up the same way or do I need to put in new motor mounts? This is my daily driver so I have to do this in one Saturday and need to make sure all my ducks are in a row.
    sorry its alittle vague
    Also what year did they swap to the 2 piece kind?
    thanks for all the help
    nathan
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    the externals of the chevy small block (283-400cid) are identical, 99%. you should be able to remove the motor mounts from your block and put them on the 350.
    I've found both types of motor mounts at local parts stores, the flat ones are not made in poly, though.
    anyone correct me if I am wrong, don't want to mislead anyone.
    ARQ.
  3. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    arq is right about the fitament, I'm not sure about the poly though. The small block mounts changed in '73. But the bolt holes in the block are all the same.
  4. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I think GMC Pauls has poly mounts for SBC engines in 67-72 trucks. About $80.
  5. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I have the old 1 piece motor mounts in my '72 truck. The part where the mounts bolt to the block is the same between the '72 & earlier and the '73 and later. The flat ones are available in poly. Check out www.suspension.com. They are $76 per pair. I just ordered some because I keep breaking the rubber ones.
    Will
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    the block is from a 75 does that mean the holes are diffrent. or did you mean thats when they changed the mount style?
    thanks everybody for allthe help
    nathan
  7. 72THING
    Nov 26, 2001
    501
    Ranburne, AL
    The holes are the same on the block. They changed the mounts in '73 I think. The older one-piece mounts will bolt up to your '75 block. My block is an '81 and I'm running the old style one-piece mounts.
    Will
  8. Murph
    Murph Registered Member
    Mar 13, 2001
    40
    Seattle, WA
    I put a 91 5L TPI motor in mine and the mounts bolted up just fine. Like arq said, the block didn't really change. The block is still SAE, but everything else is metric. Pain, but you have to credit GM in making things interchangable and standard.
  9. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    cool thanks for the help i'm just a little paranoid
    nathan
