Motor Mounts on 1990 K5 4 x 4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cinquecentoe, Oct 27, 2002.
  1. cinquecentoe
    cinquecentoe Registered Member
    Oct 20, 2002
    12
    Southern Germany / Stuttgart
    All,
    this is me again, the German with the vibes on the '90 K5 4x4.
    Anyone can say how the engine has to sit in the engine compartment ? We checked yesterday with a "water-level".
    Mine tends to the passengers side, it is lower on the right than on the left -drivers- side. Couldthat be a worn motor mount, or both sides after 12 years ??
    Any recommondations on changing the motor mounts ??
    Thank you, have a nice sunday.
    Regards Alex
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Have someone sit in the truck (that you trust ;->), apply the brake put it in drive and rev up the motor a little at a time, do the same in reverse. If the motor jumps one way more than the other than you have a worn out mount, mine was broke and I had problems busting exhaust manifolds on the passengers side (drivers side mount was broke). When we done this I could see the motor on the drivers side jump up like 2 inches (I think in reverse) from inside the truck with the hood open. I had problems getting the right mounts from the auto parts store, got the right side when I needed the left took it back got the other and got one that the rubber part of the mount on the inside was installed upside down and I went to another auto parts store with the orginal in hand and finally got the right part! Good luck, the install is not that hard in you have 3 or 4 hands and good jack.
  3. cinquecentoe
    Oct 20, 2002
    12
    Thank you for your advice
    Alex
    /forums/images/graemlins/smile.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
