motor mounts on a big block and small block
Discussion in 'The Garage' started by burbanbeast, Feb 12, 2007.
  1. burbanbeast
    burbanbeast 1/2 ton status
    Jan 24, 2006
    103
    Collierville
    ok. i have a 1989 v1500 suburban. it came stock with a 350TBI engine and i am trying to swap a 454 into it. now i talked to cybrfire about making some motor mounts and the question he asked was are the mounts gonna be the same as in th 87 trucks. from what ive read the 70somethin to 87 pickups are the same as the 70somethin to 91 blazers and burbs at least suspension wise. now does that apply to my motor mounts as well? and should i ask him to make small block mounts or big block mounts or are they the same?
    ive also read that to ensure the engine fit properly that i need a body lift. and i have seen some mounts cybrfire made that had i dunno 1in of lift to em so should i ask for that as well? thanks
  2. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,613
    602
    Hooper, Utah 84315
    First question did 89 trucks have a big block option?
    yes is the answer
    So motor mounts should available, if not the same.
    A body lift will not be needed cuz the factory did it without them
  3. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    SBC and BBC mounts are identical.
  4. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    Just drop it in, it will fit. No lift, no changing the mounts, though I would run Polly mounts.
  5. burbanbeast
    Jan 24, 2006
    103
    Collierville
    sweet thanks guys ill relay the info to cybrfire and hopefully get this project runnin
