Motor mounts
Discussion in 'The Garage' started by 1987Blazer, May 24, 2005.
  1. 1987Blazer
    1987Blazer 1/2 ton status
    Apr 9, 2005
    168
    Murrieta CA
    I need to replace the motor mounts on my 87 k5. Can anyone suggest a good brand?
    Steve
  2. tucsonkfive
    tucsonkfive 1/2 ton status
    Jun 9, 2002
    133
    Tucson, AZ
    I picked mine up at Autozone a couple of years ago and they seem to be fine. Running a mostly stock engine but had no problems. :)
  3. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i got a set of the ord motor mounts and they are a heluva lot tougher then the stock ones but do transmit a bit more vibration to the frame if you feel its worth the trade off
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I used the Energy Suspension ones that you fit to the stock metal clamshells. When I did my motor swap the old stock ones just fell apart when I took them out, the rubber had totally dissintegrated! (spelt wrong :o )
  5. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    If you do go the poly motor mount then you should replace the tc mount with poly also. You don't want one to be a rigid mount and the other one soft or you could end up cracking something.
