Motor Mounts ????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by opfor2, Mar 10, 2003.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Hi all,
    I would like to change my stock motor mounts and replace them with polyurethane from energy suspension. However, they don't list any mounts or incerts for my vehicle. Has anyone else replaced their mounts and if so what type did you use.
    thanks
    Dan...
  2. dyeager535
    26,979
    Dan, went down to my local speed shop, we grabbed both of the "biscuits", and took them out to my truck to compare. There are two "thicknesses" of motor mounts, which is what you need to make sure of.
    They were no more expensive at the local place, and I knew they would fit, so it made sense to by them that way.
    Haven't installed them yet, but since you re-use the stock steel halves, you might try looking the "inserts" up for an earlier truck, ('81-87 K10 for instance) just to make sure you are looking for the right part, if you are trying online or in a catalog.
    To clarify a bit, my '81 frame (with '74 350) uses the clamshell mounts, but there are still two different thicknesses of them. I doubt the later trucks such as yours use any different "style", but the thickness may have changed.
  3. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    I replaced the motor mounts on my '89 Sub with Energy Suspension polyurethane units. I have the three-bolt clamshell style motor mounts, so I used part #355-3-1121G from the JEGS catalog. Check out the website page I just listed and look about 2/3 down the page. I have had no problems with the mounts so far and they have worked well.
  4. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    Thanks, I'll look it up and see. I think that your 89sub is just like my 90 blazer isn't it ?
    dan..
  5. BigRed89
    Oct 28, 2002
    223
    Los Angeles, CA
    As far as I know your mounts are the same as mine. Maybe someone else will chime in to confirm this. Good luck!
