MOtor prob HELP
Discussion in 'The Garage' started by broncoman6524, Jul 27, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    alright yesterday my motor was making allota noises that i aint never heard before. got home checked the oil...it was below the add line (it was actually dry:eek1: ) My radiator also needed water.
    Today i drove it again, it runs fine except for when you get on the throttle when i gets up into higher rpms (ready to shift) it starts backfiring through the carb. when you let off it no longer has the ravenging exhaust pulses that i love so much lol.
    I know that i have a stuck lifter as i can hear it at idle. WHat could be causing this problem? i've fiddled with the timing and it hasnt realy helped much. Hopefully i havent burned anything bc of the low oil :mad:
    thnx chris
  2. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    TTT HELP its realy starting to piss me off
  3. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    pull your valve covers and see if the push rods are where they are supposed to be I have a feeling you might see one of them peaking thru the rocker
  4. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    fixed it, it was a loose rocker arm.
